I used my tractor the other day, three days later I wanted to use it, when I choked it and turned the ignition on nothing at all happened. So, I checked the battery and it was OK, I then test lighted the ignition, and the power was always on even when the key was off. I then noticed that the key now turns 180 degrees in the ignition. I took the positive cable off of the battery so not to discharge the battery. So, what I wanted to know if anyone could tell me if the ignition is the culprit ? or maybe something else. Please remember that I had no prior problems before putting it away till the next use. It ran perfect with no noises or anything that would tell me that I had a problem arising. Thank you, Bill
