john deere 12a combine
dcross
Going to pick up a 12a combine and know the tires are bad. Wondering what the bolt pattern is to see if I can take tires I already have to pull it home.
I think You have spoke wheels on a 12A. I dont beleive that ball bearing hubs with solid wheels came until the "25" came out. I took tires of a 55ABH plow off about 20 years ago. It was pretty easy, & almost as fast as changing a new tire. If I remember correctly there is a single pin through the axle that holds the hub on. Just take the 3 bolts out of the hub cap, remove the cap, & you will see the pin. Make sure its in good shape if You tow it over the road, & well greased. I think these hubs take about 1/2 - 1 full tube of grease each.
Scotty
