john deere 1520
dfrost
I'm having trouble with slow hydraulics on the loader & 3 point lift. the steering and brakes work fine. Any ideas on what to check? this is on a 1969 john deere 1520 with a model 48 loader
When was the last time the tractor received it's annual or semi annual check and or change of the screen and filters?1-800-522-7448
How is the loader plumbed into the tractor?
I should have said that I"m looking at the tractor to possibly buy it, and they say the filter, screen and oil have been changed. And the hydraulics have always been slow on it. There is a T fitting near the filter with one side going to the loader, and the other going to the remote connector on the back
The loader with be slow unless it's supplied direct from the high pressure line down in behind the brake cylinder. The oil has to return into a ported filter cover to prevent the front high pressure pump from cavitating. Anything to do with the scv's is for the birds.
What brand of loader? It's possible somebody has an open valve on there which works poorly with a closed center tractor.
Check real close for the slightest hint of brake linings or metal. Some people ride the brakes or beat the brakes to death with loader work.
Test the engine coolant for corrosion inhibitor. If it's depleted the sleeves will be cavitated to bits.
Are you sure it's got a hydraulic pump on it capable of running a loader? Many 1020s and 1520s do not.
Original equipment on that tractor is often a German .69 cubic inch pump which is tiny. The optional pump was another German pump at 1.38 cubic inches, i.e. twice as big and still tiny.
Compare that to the small standard Deere USA pump that is 2.4 cubic inches, and the larger 3 cubic inches.
If it has the OEM .69, it will always be extremely slow until it gets a different pump.
it has the pressure side plumbed behind the brake valve, and the return line plumbed above it near the seat. It doesn't have a filter housing with the port in it,will it work correctly if I fabricate my own port, or does it have to have the factory port?
(quoted from post at 10:11:42 11/07/09) it has 8 bolts
Good news. it's the 10-11gpm pump. Small but respectable. It's all my 1640 has but with the direct supply and ported cover, it's usable. On does have to plan ahead and start lifting the loader before getting to the spreader etc.
It's always a bit of a surprise getting onto my Father's 2355 with the 3.0cc pump after using the 1640. Loader speed is almost twice as fast.
