John Deere 2010 fluid change
Gregday
I recently purchased a John Deere 2010 and I need to change the trans and hydraulic fluid. Could someone explain to me where the fillers are and how much I should put in. Thanks.
Hyd filter(screen) is accessed by removing cover held in place by 3 bolts on RH side of clutch housing. Screen is designed to be cleaned with a solvent & reused. One determines if screen is clean by setting in a pan closed end down & pouring hyd in the center of screen. If oil easily flows out screen is clean. Trans should hold around 7 gallons of hyd oil.
Besides the motor oil and the 7 gals of hydraulic In the trans is there
anything else I should change? The fill plug for the trans is right
under your right foot correct?
Yes hyd/trans oil fill/check plug is close to right heel when operator is setting in seat. If tractor has manual steering one should check oil level in that gearbox. IIRC the final drives on each side require oil level changed/checked
(quoted from post at 14:28:02 04/21/20) Besides the motor oil and the 7 gals of hydraulic In the trans is there
If I remember correctly, each of the final drives require 4 quarts of 10W-30 engine oil. I just use Hygard.
If I remember, I will look in the service manual tonight and confirm.
