D parts web site has a wiring section that shows the different electrical parts, but the wires are not color coded and run together in bundles, poor at best. They also change by serial #.(quoted from post at 00:15:43 09/23/18) Thanks for the replys. The tranny is in neutral, and the pto, non-elec. is off. Engine cranks but not start. It started before I took the old seat with the switch off. Started about 3rd revolution all Summer. Only change was removing the seat with the seat switch. Is there a wiring diag. available to see what all is there? My operators manual does not cover wiring.
(quoted from post at 18:15:43 09/22/18) Thanks for the replys. The tranny is in neutral, and the pto, non-elec. is off. Engine cranks but not start. It started before I took the old seat with the switch off. Started about 3rd revolution all Summer. Only change was removing the seat with the seat switch. Is there a wiring diag. available to see what all is there? My operators manual does not cover wiring.
(quoted from post at 06:52:06 09/28/18) A wiring diagram helps. I had the same problem with a L110. Looking closely in the "cable" female plug that mates to the seat connector, there was a thin piece of metal deliberately inserted to short the 3 pins together (as I recall 3 pins). Removing that piece of metal with needle nose pliers, allowed the connector to hang loose and the engine start.
(quoted from post at 09:41:33 10/08/18) Well, I gave up and took it to a Mower repair shop. Only thing they found was a blown fuse in a line behind the light switch. If this was added by a previous owner, don't know. Bottom line its running again. Thanks for all the suggestions.
