Wendelspanswick
Hi all,
Every time I park up my 2130 with 175 loader it leaves a patch of hydraulic oil on the ground, a good half pint!
I traced the leak to a hanging small bore plastic pipe that seems to run from the top of the hydraulic reservoir above the pump. There are two of these pipes, one runs to the air intake and the other just hangs free. I am pretty sure it should be connected to something as there is a spring wire hose clip on the end. Where should this connect to and any idea why so much oil is coming out of the pipe which I guess is a breather pipe?
The hydraulics are pretty poor on the tractor with a fair bit of shudder but I can live with it for now.
An update, I placed a empty plastic bottle over the end of the pipe and 10 minutes use of the tractor hydraulics results in a small half cup full of oil in the bottle
Cheers in advance.
John
Cheers in advance.
John
