John Deere 214T baler
jachamar
It wasn't use for 30 years .The pump doesn't pump at all (It has enough grease).Any advice .
Thank you in advance
I'm more familiar with a 224T, but are you talking about the greasing pump? Do a search on either 214 or 224, seems to me I've seen other posts about clogged grease lines causing pump not to work.
It does not use "grease". It uses a special "multi-luber" lubricant. Grease is too thick. Remove all the grease from the canister and plumbing to the pump. May have to take the pump and lines apart and blow the grease out of the lines.
The special stuff will pour but changes to semi-fluid like grease when pumped under pressure. See your John Deere dealer for the stuff.
Google rheopectic!
Good luck.
If you are going to use this baler the best thing to do would be to remove the pump and install grease fitting were each line goes. Multi-lubers were an option with very few balers having them. With age the lines can pinch or become brittle and break.
tomstractorsandtoys1, that's a great idea.After replacing the fittings Do I need to use the Multi-Luber or I can use regular grease ?
