john deere 2240 brakes
foxhoun
I am having trouble on my 2240 with the right side brake pedal sticking in the down position. It will not return to home position without pulling it up manually.The left side works fine.
If the pedal isn't sticking on it's pivot pin, most likely the brake valve needs to be rebuilt.
If pulling it up by hand works the pedal is sticking on the pivot pin. Free it up and it should be fine. If bad enough you may have to remove and clean up the pin.
