John Deere 2640 hydraulics
I have a John Deere 2640 with a single hydraulic hookup and because it has a loader there is another set of hydraulic couplers to run the loader through a joystick. I have a piece of equipment with two sets of hydraulics. Can I disconnect the hoses that tilt the bucket and hook up the hoses for the equipment.
Are you saying you have one set of remote couplers run by one SCV and the loader valve gets its oil from another set of couplers not connected to the rear remote couplers? Or is the loader valve supplied by the rear remote couplers?
I think you are saying the first is how you are hooked up. Look into a multiplier valve to install in your rear remote couplers. You can have two circuits controlled by a switch and the one SCV you have now, while leaving your loader plumbing untouched. I attached a link of one I use on my tractor when I need two circuits. I didn't see them but may be available through this site or PartsASAP. Several sources have them.
Remote circuit multiplier valve
Yes, you could use the loader bucket cylinder circuit to operate another function.
Being closed circuit hydraulics on a 2640 you could Tee into the supply and return points for your loader and add a single spool valve to control a second set of rear remote couplers
So a endgate for the bale and a pickup raise and lower? I’d drop the pickup when you get to the field set the wheels and switch to the gate by hand
Although we don’t use them since the usual tractor has 4 valves the Vermeer has a manual valve in 2 of the 4 hoses to allow you to do this and relieve pressure
A 2640 would be light for this unless it’s a small round baler is this a backup plan? Trying to finish cornstalk bales maybe?
Even our backup 4440 would be considered a bit light but doable
I’d stay out of wet spots up here it’s been never ending rain got a hard frost finally was going to sneak out early with the P&k spreader
What you asked utilizing bucket hyd control circuit can be utilized to control a hyd function on a baler.
Another option JD engineers utilized back in the 1970's was a manual operated hyd splitter valve manually controlled by pulling a rope. Fasse also makes an electric controlled splitter valve.
I think a JD 2640 will handle a rd baler on virtually level soil just fine. When AC clutch failed on my JD 4255 I pulled my JD 467 rd baler making 4X5.5 rd bales just fine with my Kubota M7040(64 pto hp) on level soil.
I baled for a couple years with our 2030 and 435. Even made some 4x6 bales and not a lot of the ground was flat. Admittedly the MF 1105 we use now has an easier time with it. 2640 should be fine for a backup. JMHO
Why is the loader supply/return micky moused into the SCV ?
The loader joystick is supposed to supplied from a T between the priority valve and the SCV .
The loader is supposed to return oil to a ported transmission filter cover .
Once you correct the loader supply/return .#1 the SCV will be available for the loader. #2 the loader will operate so much better . That you will want to find the slob that originally connected the loader . Then call that person a long list of bad names . Telling them how dull witted they are .
2030 has a 3.6L(219 cid) engine @ 68 HP while 2640 has 4.5L(276 cid) @ 77 HP so 2640 should handle a rd baler much easier.
Once you correct the loader supply/return .#1 the SCV will be available for the loader. #2 the loader will operate so much better . That you will want to find the slob that originally connected the loader . Then call that person and with along list of bad names . Tell them how dull witted they are .
Hopefully the OP comes back with better info on the plumbing of the tractor. I think he described his loader valve plumbed into a tee ahead of the SCV, but his description could go either way. The return might be going to the filter, he needs to tell us.
After re-reading the post . As you say , the loader may well be properly plumbed
A second SCV valve just bolts onto the side of the original single SCV valve .
Right, adding a second SCV to the side of the first is another way to get the second circuit.
We need all of the info about his current plumbing to see which interpretation is right. He hasn't signed in since he made this thread Friday evening. Hope fully he comes back and replies soon. Even if he figured it out, he could sign in and post what he has done to close this out.
I assume your loader was installed using a connection directly into the closed center system with the return to the filter housing. You could disconnect the bucket circuit and connect the baler twine control to the bucket valve. You could add an additional closed center valve to the loader system.
2nd hyd circuit that burnsq2003 referred to could be a Tee hyd fitting behind PCV & a ported filter cover.
Agreed, that was my thinking in post # 4, that is how my tractors are plumbed for the loaders with dedicated loader control valves. burnsg2003 needs to reply back here and improve the plumbing description so we can be clear on what is there to help him more.
