John deere 3010 Hydraulics
vinnivee
I went to use my John deere 3010 Diesel this year and the hydraulics will not work. What do I need to check first other than the fluid level? Need help
Vince
Ditto on how long since hyd filter has been changed & hyd sump screen checked/cleaned? Check frt pump coupler to be sure pump shaft is turning when engine crankshaft is turning.
(quoted from post at 20:23:26 02/19/18) I went to use my John deere 3010 Diesel this year and the hydraulics will not work. What do I need to check first other than the fluid level? Need help
Vince
How cold was it and is there water in it. Mine sometimes has to idle for a bit before the hydraulics work.
I changed the filter and added hyd fluid to the full mark. The hitch only works when I rev it up to 1200RPM. The steering doesnt work very well ....
What now?
