John Deere 3010
With one day as the time to get stuck, it likely is easy to unstick. Move the tractor to a location that is free of obsticles, and open to forward motion. (if it is a diesel, upy may need to get it warmed up first, then shut it off.) Do not do this in a building! Put it in a medium tillage gear. Push down the clutch pedal, and start it. It may just start normally, as the starting rotation might break it loose. If it drives forward, be ready to steer and operate, as well as shut it off if you even begin to run out of room to drive. Apply the brakes to assist in getting it free. Once free, use it as needed, then when parked, block the clutch pedal down to keep it from sticking the next time. Jim
(quoted from post at 11:38:58 12/13/20) one of the springs in the pressure plate could have broke.
If it is not simply lightly rusted/stuck it's likely the one of the three release bolts has broken.
NOT uncommon with those clutches.
With the engine NOT running, the O.P. needs to take the inspection cover off of the bottom of the flywheel housing and check to see if one of the release fingers can be depressed with no tension on it, indicating the bolt associated with it has broken.
Or, short piece of bolt with two thin locknuts on it may fall out as the cover is removed.
