john deere 301a diesel
randyi
started leaking or blowing hyd fluid from tank on top of air filter. I havnt started to look for possible leak yet what else could cause it ?
thank you
My 1st guess would plastic drain line(items 1 or 27) for front hyd pump has failed.
Also check the hose (#6) between the tank and tube to the main pump, right under the tank. I have had those fail. Those need to be the correct oil rated hoses, NOT heater hose, even if that is what it looks like.
