Glen D Anderson
Good day!
We have a '64 3020 that is in need of new rear tires.
It's currently equipped with 18.4 - 30s in the rear & 10.00 - 16s in the front, used primarily for loader work hence the larger front tires....
Would like to install 34"s on the back to help level things out due to the 10.00 - 16s on the front & to gain a little speed as 5th fwd & rev are a bit slow with the 30's.
Hoping to do this with a 30" to 34" step rim I contacted a local wheel supplier, as well Unverferth, who both said that combination is not available, nor anything in the 30" wheel size for that matter. They were however able to build a custom flat plate style rim that would bolt to face of the existing factory cast center utilizing the holes for the clamp bolts.
Short of swapping out the original 30" cast centers for 34"s is there any other way to accomplish this or does anyone know of another supplier for 30" to 34" step up rims?
TIA
TIA
