John Deere 3020 hydralic oil level
jackson63
I just bought a 1968 3020 gas with a JD148 loader. Pulling the hydraulic dip stick it shows over filled by a half inch. Is that correct because of the need for extra hydraulic fluid to run the loader? Or should I fill it to the full mark. Do you check the level cold with the dip stick sitting on the threads? Thanks
The manual says to check it with the cap setting on the threads.
You download and save a free pdf copy of the operator's manual from the JD Ag & Turf Bookstore. Use the Equipment Publications button to get to where you do a model search (you should have your serial number as there are several 3020 manual breaks).
John Deere Ag & Turf Bookstore
