John Deere 3020 Starter
poppoboy
Does the starter on the 3020 diesel need to be greased? There is a plug on the back that may be for a grease fitting. The 3020 is a 1964 with two 12 volt batteries.Thanks for any help.
Many starters had them plugs. There is a felt in there that
lines the bushings the bushings have an oblong hole and
that felt rides right on the shaft. Remove plug and give it
a squirt of gear oil and replace plug.
(quoted from post at 11:15:09 03/26/23) Many starters had them plugs. There is a felt in there that
Thank you for the help..Will give it a good squirt of gear oil.
