DodgesandDeeres
goodmorning gents, i have a John Deere 3055 that im having an issue out of the hi low, i rebuilt the unit and have rebuilt several over the years, in this particular one i rebuilt all the clutches, seperator plates, piston seals. reassembled and it hold good shifts good but the problem is when i clutch the tractor it immedialty stops like the brakes are applied, i used the shop manual when rebuilding was very careful reassmbling, pressure checks around 150 (148ish). i jacked the tractor up engine off everything rolls easily and smooth, engine started some resistance not much, put it in gear and hit the clutch BAM! IT STOPS. im baffled as i have never had a problem with these before, also all the orings and pipes were changed along with the trans oil pump while i was in the thing.
