John Deere 310A Clutch
whrowley
I have a 1976 310A which runs fairly well for its age. Clutch is starting to act up. Don't have much clutch pedal left, last inch or so. Is there a way to adjust the clutch to give me more foot pedal? I expect to eventually need to replace the clutch but trying to avoid as long as possible..
From viewing 310A parts schematic it appears there's a threaded yoke on clutch operating linkage that could be adjusted to get more pedal free travel but I don't know if that would give throw-out brg more clearance from pressure plate fingers.
(quoted from post at 03:22:43 11/02/18)
Ill give it a ty, Thank You
Turns out there is a small linkage rod under the clutch pedal. Few turns of the rod made the adjustment. One way is in and the other is out. Easy fix, 5 minutes.
