JOHN DEERE 310A
TODD IN FLA
HI ANY HELP WOULD BE GREATLY APRECIATED....I HAVE REPLACED THE FRONT LOADER HOSES ON JD 310A AND MY DIAGRAM WAS WRONG AND I HAVE A HOSE IN THE WRONG PLACE...IS THERE ANY ONE WITH A HOSE Schematic THAT CAN HELP....I GET THE LOADER TO LIFT UP AND DOWN BUT THE BUCKET IS NOT OPENING OR CLOSING...NO PROBLEMS WITH LOADER PRIOR TO THE CHANGE....THANK YOU KINDLY...TODD
Just follow the hoses. At the cyls. the hoses that go in the same end of the cyl. should tee together then run back to the valve. If they are crossed at the valve it would just work but opposite. So I suspect you may ? have one of the bucket cyl. rod ends hooked to the others piston end. Criss crossed to put it another way.
