John Deere 310B Backhoe
Stumbler
I have a John Deere 310B backhoe. The brakes operate on the Backhoe's Hydraulic system. Lately they have been getting tighter and tighter to the point where they actually start to pull against the power of the backhoe. I have removed the pressure relief control valve because it was giving me problems. I know that this valve controls the power steering pressure so the backhoe can be started, but does it also have any control on the brake system? Thanks for any inf! MWB
Sound more like a problem in/with the brake valves, not the pressure control valve.
The Technical (service) Manual for it should help diagnose, and rebuild if needed. The manual for the 310B is John Deere publication # TM1158.
Pressure control valve has no connection to brakes. Pressure control valve was designed to give power steering priority pressure/flow when operating other hyd controls. Brake valve housing is supplied oil via trans pump not front hyd pump. Do brake pedals rotate easily on brake pedal shafts?
No, the brake pedals get tighter just like you're actually pushing them. The tractor actually gets slower & slower. You can bleed the brakes on top of the axle which will bring the pressure back down for a little while before it starts to rise again! ??????????
