(quoted from post at 19:09:39 05/22/18) P218 onan engine. Hard to start. I put check valves in fuel lines..cleaned carb. I restored this. It runs great but very hard to start. Put new fuel pump on..new lines..still hard to start. It has no points..help?
put all new lines in tank as well as check valves..no difference in starting. Gonna check valve clearance..but i doubt this would cause this. My next step is a electric fuel pump..if this dont fix it..im sticking a kawasaki in it..ged up with onans.(quoted from post at 05:35:31 05/23/18)(quoted from post at 19:09:39 05/22/18) P218 onan engine. Hard to start. I put check valves in fuel lines..cleaned carb. I restored this. It runs great but very hard to start. Put new fuel pump on..new lines..still hard to start. It has no points..help?
Valve lash
(quoted from post at 21:44:18 05/22/18) External pump, lots of sources for a low pressure fuel pump, even NAPA has 'em.
The 322 uses a DEERE AM876265 pump, DEERE wants well over a hundred $$$ for them, Check on the 'net, ebay for example, and you will find imported substitutes for $12 and up, shipped, and I've had hood luck with 'em, at least so far!
Power from a terminal on the ignition switch that's "hot" in run and start. IIRC, there's a loose yellow wire pigtail with connector behind the "dash" that can be used. I use an in-line fuseholder with a small fuse, 5 or 7.5 Amp, just in case!
(Automotive electric fuel pumps typically use an oil pressure switch, or other means to shut them off if the engine stalls. The 322 and the 400 weren't set up that way and run as long as the ignition switch is "ON", so be aware of that option.)
Here's what the imported pumps look like, similar to the OEM pump used on the 322:
So do i plug the cranckcase line?
<img src = "http://oi63.tinypic.com/nei91g.jpg">
(quoted from post at 06:10:14 05/27/18)/quote]h(quoted from post at 21:44:18 05/22/18) External pump, lots of sources for a low pressure fuel pump, even NAPA has 'em.
here is my restored 318. Bought it for 300.00. Still hard to start..next step is an electric fuel pump. She runs great once its started.. crank the damn thing 27 revs. Before it fires.![]()
