John Deere 350-B Trouble
HeatherCater
My 350-B seems like it has no hydraulic pressure. Seems like it doesn"t even want to move when it gets warm, and when you engage the reverser, it doesn"tseem like it does anything at all. The only real power the machine has is curling the bucket. I did just replace the hydrauic filter, and part of the old filter had disinegrated into the case. The more troubleshooting information I get, the better, because I don't have a manual. Thanks so much for reading!!
The filter inside the reservoir disintegrated???? Sounds like we have filter junk stuck all over the suction screen in the bottom of the oil tank..This keeps the oil from being sucked from the tank to the pump..Release the air pressure from the tank by removing the fill cap..Drain the tank, plug at the bottom above the track and sprocket..I use 4" pvc 90 degree elbow and a short length of pvc pipe glued to the elbow..Have about 2, 5 gallon buckets real handy..That oil's gonna come right out..Take the top cover off and feel around in the bottom for the suction screen....
The crawler not moving has nothing to do with the blade going up and down. Two totally different systems.
As to the suction screen at the bottom of the hydraulic tank - you don't have to drain the tank to get to it - if you don't mind sticking your hand in the oil. The suction filter is held on by spring-loaded clips and pops right off. It's routine maintenance to pull it out once in awhile and clean it (it's metal mesh).
As to the hydraulic return filter that is supposed to be bolted to the top-cover on top of the hydraulic tank. It's paper and is often not there. Tends to fall off. That because it's held on by a long 3/8" bolt - and a long spacer that goes inside the filter and allows you to tighten that bolt without crushing the filter. Most of those spacers get lost, then the bolt can't be tightened very much, and the filter soon falls off. There is a hydrualic filter restriction indicator the pops out of the top of the tank. If the filter is still there, even when it's clean - you should see that indicator jump up and down at cold starting. Once the oil warms a bit, it stops. If it stays up all the time, the paper filter is still on and plugged - OR - the oil is too thick.
The reverser has it's own paper filter inside the reverser case.
