John Deere 350c Reverser
Jamie Dunn
JD 350C crawler. Works great but the reverser is now not working. Started out that I needed to use the clutch to go forward or reverse using the reverser. Slowly the reverser has engaged slower and now not at all. For a time, if I was pointed up hill and it could slowly roll or easily roll backwards it would work and was strong. When engaged it pushes well/strong. Fluid is fine and new filter. This process has taken about 3 years. Just progressively getting weaker.
Welcome to the Forums. You need to do the adjustments and pressure checks by the manual, but it sounds like the pump or reverser clutches.
The 350s used an isolator, not an engine clutch, so it is not an engine clutch issue.
Got all cleaned up today and will the pressure tedt tomorrow. Goes into reverse when cool but stops when it heats up.
