John Deere 40 help
telephoneman
I looked at a JD 40 today. It"s been stored outside for several years under a tarp. While hand cranking the engine water poured out of a hole in the manifold. How bad might this be? Is there any chance the engine could be saved? This would be a winter project. I"m handy with most tools and not afraid to get dirty. I just don"t want to get involved in a money pit.Looking at about $800.00 to buy.
Any help would be appreciated.
Whether this is help - or not - it's my two cents.
Water out of the manifold probably means a cracked head - and if turning it over pushed out the water, then at least one cylinder has had water in it. Replacement heads, and engine parts are readily available - so finding parts won't be a big problem. JDs are green for a reason - some funny little parts from the dealer will cost more than crackers at WalMart.
What is the general condition? If the nose piece is all beat up, $400 will get you a good one. Tires shot, or useable? Are you goona play with it, or use it? A hydraulic leak is something you can live witrh when just putting around, but if you plan to mow your estate with a 3pt finish mower, you'll need it to be in good condition.
What model? If it's a 40V or 40H - stop reading and go buy it. The 40T was the most common, then the 40S, and then the 40U, and then the 40W. So, everything else equal, a 40W would be more valuable than a 40T ( a 40T does NOT have the T stamped on the serial # plate - the other models do have the letter designation on the serial plate).
If it's all beat up, tires shot, etc I would not pay more than $800 for a 40T - but if you're looking for a project, it cxan be fixed up with some money, some time and you'll have a good result.
www.jd40.com
Since it turns over that's a good thing ! Was it just rain water or antifreeze ? rain water is no big deal ,yet, since it still turns over. check the rad. for being full and the engine oil for being normal. Lokk VERY closely at the front side of the cyl. head and the LH side of the block behind the carb. area. These are VERY common spots for cracks. If the block and head aren't cracked it should be a keeper.
T-man,
You already had some good advice by mike and JC. As stated, if the block is cracked, punt; that is unless you have access to another block for a good price.
Since you can not start it, there is no way to check the transmission or the hydraulics. If you want to restore this to show, then all the tin and other comes into play. If for a general working tractor, then new paint, tin, time and alot of money is saved.
On the electrical side, you have the generator, starter, ign switch; points, s-plugs and wiring is cheap, but the former are not...see if you can pull the genny/starter and look at them.
Does the gas tank look solid or is it rusty or any thin metal? Is there gas in the tank? Open the s-cock on the carb [make sure gas is turn-on first] and see what comes out?
Check the radiator too and see what is [or is not] inside? How are all of the tires and the rims? check for rust spots/holes near the valve stems...pump some air in and see what happens.
There is a lot of inspection and guess work when it will not run and heat-up. If you have to replace a lot of what has been listed, it can ADD up. Finally, why is it being sold?
Good luck,
tstex
