John Deere 40 Touch o Matic drain plug
I have just bought a John Deere 40 and I am going through and changing all of the fluids. I need to change my touch o matic oil however the drain plug looks like it has a square hole instead of a traditional head where you can get a wrench on it. Am I looking at the right one and if so what do you recommend I use to get it out? Thanks!
Greg
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">Am I looking at the right one and if so what do you recommend I use to get it out?[/i:654c4848f0][/b:654c4848f0]</font>"
If you are looking at a Model 40S (Standard), then yes you are looking at the right one.
Take a look at the [b:654c4848f0]TOUCH-O-MATIC ROCKSHAFT ASSEMBLY Standard[/b:654c4848f0] below.
a273663.jpg" width="650"
Note the 3/8 inch pipe plug (Key 20) part no. [b:654c4848f0]15H 583 A[/b:654c4848f0].
Take a look at the photos below of "Audie" our 54 Model 40S.
a273664.jpg" width="650"
You might consider using a piece of 1/4 inch key stock to remove the plug.
a273665.jpg" width="650"
Hope this helps.
