john deere 400 /2010 loader
broken
i have a john deere 400 industrial i think someone replaced loader valve with an open center valve possibly off a crawler outside looks identical but internals are different. can i convert this to closed center
John Deere did use some hydraulic control valves that were convertible. They have a large plug that changes the valve from open-center to
closed-center. I don't think they came out though until the early 1990s. Not back when the 400s were made.
(quoted from post at 18:22:40 03/28/20) i have a john deere 400 industrial i think someone replaced loader valve with an open center valve possibly off a crawler outside looks identical but internals are different. can i convert this to closed center
Maybe, maybe not, it will be hard to say one way or the other. You can see what you have for a valve and you aren't sure what it is. Offhand I would lean towards no, if it is truly a dozer valve. JD built many of those for the application, open center. If it happens to be an open center with a conversion plug already in it, the main relief needs to be adjusted up to its full extent so it will not open when on a closed center system.
I just bought this machine. My issue is fluid getting hot and as soon as i hook loader valve up it tanks my stand by pressure. I pulled the front end loader valve where plug 21 is i have this which i think is a flow control. I also have the same style valve at location 21. The check valves are different also. Instead of a spring and poppet i have a cone style plug and plastic balls.
https://www.yesterdaystractors.com/cvphotos/cvphoto9950.jpg
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto9951.jpg
JD offered hyd control valves that could be converted from OC to CC.vice versa via plug(item 12A or 12) as far back as mid 60's.
Simple closed center test is disconnect control valve return hose from tractor hyd system. Aim open return hose in clean bucket &amp; with control levers in neutral,start engine &amp; no oil should exit open hose.
This diagram is the valve i should have. And it looks identical. Except
where parts 10 through 15 are and also 21. I pulled this valve out of
there in both locations. and when running with return disconnected
fluid flys right through
(quoted from post at 08:07:34 03/29/20) and when running with return disconnected
Your hyd valve either was intended for open-center system or has a blown internal seal causing it to revert to open center configuration which needs to be corrected before closed center system can operate correctly.
