John Deere 4020 rear wheel weights differences
normmax
I have purchased wheel weights for my 4020. They are different and will not go on right. The # on them are r61524 and A3404R. How can I stack these on the tractor wheels? I have 4 of the first number and 2 of the second.
Most likely you have two with a different size centers. The big center weights were made when the 4440's came out. The bolt patterns are the same so you should be able to put those on the outside. Tom
IIRC the wheel weights have timing marks to line up the center holes so wheel tread width can be adjusted utilizing rack & pinion. 1st weight mark is lined up with mark on cast wheel then next weights are turned 180° alternately. I agree that I think weights with different numbers have same bolt pattern & should bolt together BUT I think A3404R should be installed 1st as it has the smaller center opening. Be sure to install mounting bolts in weights for bolting on additional weight before installing weights.
