John deere 4030 hydraulic wont float
Ok,i need help i recently bought a 73 jd 4030 from a one owner estate sale with 2600 hrs, im trying to round bale with it but when i close the back gate it will not float the gate? The baler is set up on a 1 way valve i would switch it but cannot because cylinders on baler will not allow that. I hooked up to other impliments and same thing.
ON the other hand when i was disking or running haybyne with 2 way hydraulics hooked up itworks perfect. Any ideas, when i let implments down on one way they drop about and inch and thats it.
I have tried all the obvious stuff like changing oil filters, oil, rebuilt hyd couplers, so it is something more idk maby and internal check valve or breather. Any help would be much appreciated
The early models have a valve that needs to be opened when using a single acting cylinder. It is located under a cap to the rear of the hydraulic oil filter. It is the rearmost cap. Remove the cap and open the valve (Flat bladed screwdriver required) five turns. When not using a single acting cylinder close the valve.
(quoted from post at 21:01:36 05/30/17)
Have not heard of that one.....will go and see if i can make it work in the morning after chores... Thanks verry much
590cummins
Just for clarification you are raising stop up(key 6) that will then allow SCV control lever to move farther forward??? What brand & model hay baler are you trying to operate?
In the SCV there are 4 springs that hold the poppet valves to there seat the 2 for the pressure poppets are longer than the 2 for the return poppets, if the long ones end up on the return poppets it will not go into float. The 2 marked in the picture are the high pressure ones and have the longer springs, the other 2 need the shorter springs,,some thing they are helping the valve by using 4 long springs,,and not going into float is one of the results..
Later 30 series had #2valve that dumped to
case. On a console model 20 series there
was less back pressure to filter because no
return oil from Perma-Clutch. Had a cyclo
planter and didn,t need to do anything and
single action marker came down. Put early
4430 on and marker would not come down.
SOLUTION DRAIN TO ADJUSTING PLUG TOP RIGHT
CORNER. BUT if you only are using single
hose to remote you are SOL.
I was thinking that the lever would not go into float position,,like the tab was up on the console and the lever wouldn't go forward...
Big thanks to 8nidaho he hit the nail on the head i got float now. Also thank you to everyone else for their help. But i got 1 more question when not using a one way hyd cylinder why do i have to close valve? If i don't close valve what are the consequences?
I do not know how the thing is plumbed. I assume opening the valve creates a small controlled "leak", allowing the cylinder to bleed off. Again assuming, that the system is more efficient without the controlled leak.
Maybe someone can explain it better.
