John Deere 40S clutch
Tom Mnj
I have a challenge to work with as my tractor broke down in the field with noise coming from within the bell housing area. I know I have to split the tractor and install a new clutch. I have the IT Manual and have installed clutches on automobiles but this is my first try with a tractor.Any advise or tips will be greatly appreciated. Is John Deere the best parts source or are there other quality parts I could use?
Tom
First, a safety comment: Brace the front axle to the steering pedestal so the engine cannot rotate when you separate the tractor.
I live in a big town, and have clutch& brake rebuilders in the area. I've gotten refaced/new clutch & brake parts from them at substantially less the Mother Deere"s cupboard. Check the suppliers who advertise in GM or Two Cylinder.
Look carefully at the pivot points on the throwout bearing yoke. Probably well worn - now is a good time to bush/repin that to take the slop out of it.
I break the hydraulic lines at the rear of the gas tank to avoid the knuckle busting at the pump.
Just like a car except easier to work on.
i got a engine rebuild video and in it they mentioned that the Ford 8N used the same disk. i think Steiners sells a alignment tool for aligning disk to flywheel while installing pressure plate. dont forget to check pilot bearing and throwout bearing. if you are into going the distance there may be a sheared retaining pin in trans input shaft to drive shaft that should be replaced, i used a 3/16" grade 8 bolt and self locking nut(roll pin isnt as strong). good luck, d. coleman(48M&51B)
