RiverRancher
- Location
- Central Alaska
Does the 1954 JD 40U need the 48 inch or the 72 inch coolant temperature gauge line? I’m going to order a replacement for my tractor and not sure which to order.
Did all JD 40U tractors with an hour meter have a wire going from the ignition coil to an oil pressure switch at the front of the engine below the generator? The man working on my JD said there is no second wire at the coil negative terminal and I know there is no oil pressure switch there. Were some 40U made this way or is this a previous owner’s modification?
Did the 1954 JD 40U come stock with the tall gas filler cap (AM3892T) or did some come stock with the short (normal looking) cap?
