jonnyredtractor
Had to change the end plate on the 420 starter, because the aluminum case came apart. The cast iron replacement said to change the plate so it would be CCR and to redrill the end plate 90 degrees offset. The problem is, only the positive brushes are isolated from ground on this plate and if you try to clock it 90 degrees off by redrilling it and moving the brushes you have a short. The wires won't reach to rotate the plate when the brushes are isolated. I'm now wondering if they meant the engine is CCR, which would mean the starter would be clockwise. Starter turns clockwise sitting in the seat with it assembled where the parts fit. What is the direction of this engine? Beyond frustrated.
