Freddie2010
Hi, I called to order an electronic ignition for my John deere 420w . I was told that I would also need a hot coil and graphite spark plug wires. The coil alone was another 60 dollars I don't know how much the plug wires are. Are the coil and spark plug wires absolutely nessary when I install the electronic ignition. ? thank you very much for the help. Fred
PS. I just installed a good coil from NAPA auto parts, with internal resistance when I changed it over from 6 volts positive ground to 12 volts negative ground.
