John deere 4310
Tomtom81
I have a John deere 4310 with power reverser and sometimes it wont move. You can put it in low range and select the gear then let off the clutch and go forward and it will move then stop. If you press the clutch and put the reverser in neutral then put the gear shifter in neutral then shift it back into gear and let off the clutch and move the reverser lever forward it will move again. It's like something resets when you move it all back to neutral and start over. HELP PLEASE
My knowledge of 4310 is ZERO. Do you know if reverser is controlled manually or electronically? From what you stated I'll guess electronic control. If electronic controlled you possibly have a faulty connection or relay
Tom, I have a PDF of the technical manual for your tractor, shoot me your email if wanted
Joe
