John Deere 4320 row crop
Ditto on checking/cleaning oil suction screen & changed hyd filter. Next I suggest to check hyd stand-by pressure which should be 2250-2350 psi. Is load control knob located by operators right leg in lowest position marked "D"?
When I was getting to run the field cultivator after school..... Moons ago..
Our 4320 wouldn't lift the machine up at end of the pass. Our mechanic came out, moonlight job, and yep fines in the dump and filters, main axle bearing set-up had failed inside the axle housing causing it to cut grooves into that inside casting, thus where the fines came from. GG Wes.
