John Deere 44 plow
DJL
I picked up an old plow last fall and now want to restore it. It"s a John Deere 2 bottom trailer plow on rubber with spoke wheels. The back tail wheel is also rubber mounted on a rim and is in contact with the ground during transport. The plow is a hydraulic lift and doesn"t look to have been converted from a old clutch lift type. The "44" is still barely visible. The question is what decals do I want? Is it a 44H, 44A or what? Thanks for the help.
The "H" means hydraulic lift. The "A" means the back wheel mounting; rigid mounting is no "A" and swivel mounting is an "A". From your description I believe you have a "44AH".
I don't think the "44" decal is dependent on the particular version of the plow. I have a "44H" (rigid mount rear wheel) and the number decal is just "44".
The plow could be one of 4 possibilities: 44, 44A, 44H, or 44AH.
Or if you take into consideration the plow bottom sizes it could be a 12-14 or 14-16 in any of the 4 versions mentioned above. The "bottom" cut size is changed by the way the vertical plow-bottom bracket is mounted.
Hi, believe the plow to be a #44AH,as it has both steerable and hyd. The plow can be converted from 12-14 by switching the vertical plow STANDARDS from front to back and viseversa.They are worth more because of the steerable wheel. What did you pay for it? Enjoy your plow.
the Decals are the same for them. You can get them from K&K Tractor Parts.
Thanks for the replys. The tail-wheel on mine is rigid not steerable, so sounds like I have a 44H. Does that sound correct? Thanks again for the help...you guys are great.
Also - loved the picture posted here, what a beautiful tractor and plow
I'm at the Gathering of the Green, and I went to Travis Jorde's presentaation on decals today. The #44 plows were brought up by a participant and , if I remember right, Travis said there are 7 different combinations of decals on a 44, and the best way to get the correct ones would be to take pictures of all the decals you can find and send them to him, so he could come up with the right combination of decals.
Lon
