There's no reason you can't.I recently aquired a 4520 and it has 2 6v batteries in series. I need to replace the batteries and am considering purchasing two 12V batteriesand wiring them in paralled. Does anyoner have any experience with this?
Not on this particular tractor. I agree with going with 12V batteries. A good way to wire them is independently. That is- run a positive cable from each battery to the starter solenoid, and a negative cable from each battery to near the starter.I recently aquired a 4520 and it has 2 6v batteries in series. I need to replace the batteries and am considering purchasing two 12V batteriesand wiring them in paralled. Does anyoner have any experience with this?
I added a battery box to mine and run a group 31 truck battery. I'll try to get a pic.There's no reason you can't.
A single 1000CCA Group 31 battery would probably work just fine without all the need for cable to parallel two batteries.
Thanks! I would like to see itI added a battery box to mine and run a group 31 truck battery. I'll try to get a pic.
Did same on 4020Thanks! I would like to see it
Your main gain will be from the cabling and fresh batteries, assuming you run all new cables and do separate "home runs" from each battery to the starter as mentioned above.I recently aquired a 4520 and it has 2 6v batteries in series. I need to replace the batteries and am considering purchasing two 12V batteriesand wiring them in paralled. Does anyoner have any experience with this?
What group battery, though?One of the tractors I work on is a 4620. It had a single 12 volt battery(which he replaced with a new one) when my buddy got it. On cool days, if it didn't fire immediately, it had to be jumped. We installed the second 12 volt in parallel, and it fires right off now.
EXACTLY because two 12's in parallel DOUBLED the Cold Cranking Amps. While a single or the original two sixes in series can perform okay, simply increasing the CCA and energy storage capacity can improve starting performance ESPECIALLY when its cold and needed the most. Its the OP choice subject to HIS budget and IFFFFFFFFFF he needs added CCA ??????????? Its NOT rocket science the MORE Cranking Amps and bigger battery cables improves cranking and starting ESPECIALLY when its colddddddddddddddd lolOne of the tractors I work on is a 4620. It had a single 12 volt battery(which he replaced with a new one) when my buddy got it. On cool days, if it didn't fire immediately, it had to be jumped. We installed the second 12 volt in parallel, and it fires right off now.
