In my Troubleshooting Procdure the voltage measurements are measured between the frame Ground and wherever else I'm measuring (such as coil voltage). The voltage should be measured from the coil to the tractors iron frame which, for Pos ground, means the POS BATTERY POST NOTTTTTTTTT THE NEG AS YOU STATED!!!!!!!!!!!
DEFINITION like most others (and as understood by "most" old tractor mechanics and farmers and even us electrical engineers) I refer to the metallic conductive tractor frame as GROUND. The batteries POS terminal is bonded to the tractors iron frame ON WHAT ARE CALLED POSITIVE GROUND TRACTORS. What are commonly referred to (by myself and "most" others) as Neg Ground tractors, the batteries Neg post is bonded to the tractors frame. Most mechanics, engineeres, and tractor manufacturers refer to those old tractors as Pos or Neg grounded based on which (Pos or Neg) battery post is electrically bonded to the tractors iron frame
You say you took it back to Positive Ground so THEREFORE the voltage on the coils high input side (NOT side to distributor) with ignition on and points closed with respect to frame ground WHICH IS THE BATTERIES POS TERMINAL IN THIS CASE NOTTTTTTTTTT ITS NEG TERMINAL would be 6 volts because the external series voltage dropping (12 to 6) ballast resistor drops 6 volts leaving 6 on the high input coil terminal
Take a voltmeter and place it on the coils high input (NOT to distributor) terminal with the other meter lead to the frame ground (nice clean shiny conductive part or even on the batteries POS (to frame ground) post and insure the points are closed and turn the ign swith on and you should read around 6 volts if all is correct and wired right......
EASIER TEST: (No polarity worries)
Take a 6/12 test lamp with one lead to frame ground,,,,,,,,,,,turn ignition ON,,,,,,,,Put other lead on the high input (NOT to distributor) coil terminal IT HAS TO LIGHT UP OR SHES NEVER GONNA FIRE,,,,,THERE MUST BE COIL VOLTAGE TO WORK
Okay if it lights up leave the one test lamp lead to frame ground and put the other lead over on the coils low to distributor terminal,,,,,,turn it on and crank it over,,,,the light should flash ON and OFF, its ON if points are open but OFF if they are closed
Shes NEVER gonna fire until the coils high input (From switch and ballast NOT to distributor) has voltage (with respect to frame ground) and theres a conductive path to frame ground via the points which open and close to allow and interrupt coil current flow
PUT A TEST LAMP ON THE COILS HIGH INPUT (NOT to distributor) AND IT BETTER LIGHT UP when ign is ON
If notttttttt insure current path wiring out of Ign switches IGN terminal,,,,(need voltage there when ON),,,,,,,,,,,to and through the ballast resistor,,,,,,,,,,to and through the coil,,,,,,,to and through the points when closed,,,,,,to and through the tractors conductive iron frame ground,,,,,,,to the grounded battery post
NOW ARMED WITH THIS and aware voltage is measured between the item and frame ground
CHECK THE WIRING AND RE WORK MY TROUBLESHOOTING PROCEDURE BELOW
John T
John Ts Ignition Troubleshooting
