I don't post much but always on here looking. Trouble shooting a 5055E with the 9x3 transmission. Sometimes and not always when you put it in gear and let the clutch out the engine will try to shutdown. Push the clutch back in and the engine will keep running. Shut the tractor off and let it set for a couple of hours and all is good. Put it in gear and go. At first I thought that the neutral switch was the problem. Put a new one in, but didn't help. Called a dealer and they said that it was a fuel issue, I don't really buy that. I don't know if it's a heat issue or a bad connection somewhere. I have the full diagnostics book for this tractor as well as the repair manual. Any help would be appreciated.
