John Deere 5203
I have a 5203 and Im happy with everything about it. The FEL with 4x4 is the only way to go.
JD Seller who used to post here talked one about his.A chore tractor,had a bazillion trouble free hours.
Don't get one with a reverser, located on the dash, they are troublesome..I put a lot of clutches in them mainly because no one seems to be adjusting the free travel..other than that they are good little tractors.
I have owned one since 2006 . 2wd with the 9x3 collarshift transmission. Its been a great tractor , only a couple minor things to fix since I have owned it. If you are looking for a newer no-frills tractor you should be satisfied.
I have a 2014 JD 5055d which is a similar design tractor. Use it cutting and baling hay. It has been a great tractor.
