FarmallFrank
I have inherited a 530 John Deere tractor, and it appears to have a steering gremlin of some sort, hoping someone here may be able to offer some advice.
Issue is as it is running the steering will lock up when and you can hear it under load like the pump is being dead headed, if you back off the turn it will come out of it and will usually turn the other way fine, but it will keep doing this, no set place for the occurrence just randomly and sometimes it won't, it will also pull the wheel out of your hand and turn on its own at times.
With the tractor turned off, turning the wheels are without any issues it can turn from end to end, with just a little bit of resistance at the far ends both ways, but throughout the steering swing it steers with ease, this is all being done with the front off the ground.
