I just got started working on this tractor. The instrument panel does not function with the exception of the hour meter. That still flashes.
The Dealer told me to check fuse #18 for a 10 amp fuse ,that was fine. He then told be to check the back of the key switch to see if I was getting 12 volts on #4 and #5 .I was not. I pulled out the switch and found that it was al corroded and rusted. I replaced the switch and checked #4 and #5 and I am getting almost 13 volts.
I still have no instruments working on the panel.
Where do I go from here ?
Patrick
Patrick
