john deere 567 baler error E2 04
Book says this error code means a short in twine actuator harness. I peeled the plastic cover off all the wiring and tracked it back to actuator, no bare/broken /damaged wire. Used the bypass for the manual switch to control actuator and it works fine. could this be a glitching monitor?
Also tracked the bale size circuit, thinking it must turn on the actuator at some point, no oblivious damage to wires.
Do you have a neighbor that you could borrow their monitor to determine if your monitor is faulty? How does your monitor get it's electrical power(convenience outlet or direct to battery)?
(quoted from post at 04:20:08 07/11/17)
I have 2 567's could swap them , never occurred to me. the power comes right from starter.
