John Deere 60 power trol
1954 60 power trol it has external hydraulics plumbed in but not through the back factory cylinder connection lift works fine going up but the pump makes noise when u let it down like it's pumping against a restriction but it does lower
"[b:654c4848f0][i:654c4848f0]the pump makes noise when u let it down like it's pumping against a restriction[/i:654c4848f0][/b:654c4848f0]"
Take a look at the information below on how the remote cylinder lowers.
Note the operation of the lower check valve.
Take a look at the information below on the lower check valve.
You might consider removing the lower check valve and inspecting both the ball and spring.
Take a look at the information below on the fast drop adjustment with the throttle valve screw.
Hope this helps.
