John Deere 60 ring gear and starter
sbs
buickanddeere I haven"t tried starting it with the foot pedal at all. I pulled the drive gear towards the ring gear by hand and the ring gear and drive gear do not mesh. The teeth on the ring gear seem to be too long. About 1/32 too long and it hits the face of the drive gear. The two gears just won"t slide together.
are you sure starter is mounted properly in main case there could be SOMETHING that is holding it from properly mating up to the main case surface,,,,,,,also once and a while we have had to shim a starter after a new drive was put in take starter out and check the inside mating surface good luck
