john deere 60 ?'s
MARK_H
First question I got 1953 john deere 60 just got it, Its stock, STOCK 3 point hitch alot of new parts run's good. one issuse with it, if i run the tractor in 5th 6th or 3rd gear, to make it run in 1st 2sec rev or 4th i got to take it to second gear to make it move in 4th rev or 1st if not it'S like it'S noT CATCHING THE gear'S, what could this be a shifting fork, IT dont pop out of gear dont slip when its in 4th rev second 1st after going to second first,
Sounds like a problem with the overdrive (hi/low) shifter. The trans shifts from hi to low when you shift from the right side of the quadrant to the left. Could be a worn shifter, detent, mis-adjusted rail. In any case the trans top needs to come to see what's going on inside. Mike
it dont have a high and low LIKE a OLD model A ITS A 6 SPEED TAKING IT FROM 6 TH 5TH OR 3RD, TO RUN IT IN REV 4TH 1ST, I GOT TO HIT SECOND GEAR TO MAKE IT RUN ON IN REV 1ST OR 4, if not it act's like there aint no gears in the 4th rev 1st cluster
I believe what he was saying is the old style H/L shifter was moved internal on our 60’s and when you swap the shifter from the left or right sides it then internally shifts the H/L gear. I never thought about it myself, I just went out and played with my 60 and it does feel like something shifts when moving from one side to the other.
It still has a Hi/Lo in it,its just internal,not a shifting lever like the older JDs,Its not a big job to take the transmission cover off and check it out,
Sometimes it is caused by a worn shifter. If you get any vertical movement in your shifter it must be removed to make your overdrive engauge correctly and completly.
When you pull your shift tower off move the overdrive shifter and see if it detents with the gear fully engaged into the trans drive gear. If not you need to loosen the shift rail lock screw and knock the rail ever so slightly to the right to make the mesh correct. Your other gears will be more forgiving than the overdrive since it is actually very short rounded teeth.
In the meanwhile you may be able to just give your shifter a good slap when crossing over at the bottom of the quadrant. If it doesnt work roll the clutch and try slapping it across again. When the shifter is correct it may be that tolerances are so tight that it requires you to slightly roll the clutch to cross the shifter across the bottom (engaging the overdrive).
I'm betting your problems are related to your shifter....check there first.
I have a JD 720 doing the very same thing you are talking about, I am not much of a mech.,can't get my tractor to shop right now, if you get yours fixed please let me know what you find.
