John Deere 60 starter
Still can't figure out why my 60 won't
start with the pedal but pull it 20 feet
and it starts right up could it be a ground
issue I'm stumped thanks for any advice
did you bench test the starter? see if it spins in a vise. like give us some details of what you have done . and what do you mean by engage? starter spins but wont engage?
Lots of variables. Do know if the starter actually works ? Starter switch, cables, linkage out of adjustment, poor ground. Need to do some homework.
I recently did starter work on a 520 for a friend. The copper bolt on the starter body was corroded and worn and a new starter switch was intermittent even after cleaning the copper bolt. So I lengthened the linkage so the starter switch would press harder on the copper bolt and it then worked.
