john deere 60 timing and distributor
2cylinder
I have a 60 that the distributor, and cap is pointed down toward the ground, and the spark plug wires point down also. Anyway, all the 60's I have seen have the cap and wires going horizontal with the sheet metal, what does this mean? Is the timing wrong or way off? It is pointed down alot, not a little bit
Sounds like your governor gear is not timed properly to the camshaft gear that drives off the crankshaft gear. I'm not familiar with the 60, but my '50 model B has indexing "V"'s on the gearfaces. I guess if it runs alright there, it probably won't hurt anything.
Yeah, I checked the timing today, and it is dead on, so the governor shaft timing must be off. I will let you know how it turned out when I fix it.
