John Deere 60
rickyfur
I have a John Deere 60 & would like to know what side #1 piston is on. Also would like to know how to time this tractor.
#1 is on the left side if your are sitting on the tractor, the same side as the flywheel.
On my 60 you are supposed to take out #1 plug and rotate it until it is on compression stroke then look in the peep hole in the flywheel cover and set it on 5*. Then install the distributor and turn the ignition on and slowly rotate the distributor until the #1 plug sparks then tighten it down. All of this and much more is explained in great detail in the operators manual, definitely worth it t get one.
Of course with a modern timing light you can just shine it through the peep hole and adjust the distributor until it slow idles close to 5* and fast idle close to 20*, that is if it will run.
