Anonymous-0
About 2 years ago I was ploughing and the main 30Amp. fuse blew for no apparent reason I replaced the fuse and had no further problem until about 1 month ago when the main dash board
display flicked off completely for short bursts then on again for some time before flicking off again When the display flicked off the 3 centre warning lights would flash then turn off when the display returned.
In the last week the Main 30amp fuse has been blowing seemingly only after the tractor has been running for 15 or so minutes. If I replace the fuse it runs again for a short time say 5 minutes then blows again. I thought it would be a wire worn and shorting out but I cannot get it to blow 2 fuses in a row? is it a component failure when it gets hot? Any body have any Ideas?
