John Deere 630 3 point quit working
jasonb50630
I recently restored a 630 going completely through everything including the hydraulics.
The three point hitch was working fine with no issues until I decided to use the remote outlets to try out an original cylinder I restored to go with the tractor.
I was working the cylinder back and forth to work the air out of it and decided to work the 3 point up and down and that's when I realized the hitch would not raise. It will hold position but won't raise.
Its like no oil pressure is getting to the 3 point hitch but the remote outlets work fine. Oil level is fine, and pump is on.
Just curious if anyone else has had this happen and what the cause was.
Assuming that your hydraulic pump is still engaged, try moving the remote lever to different positions as you try to work the three-point lever. There is a certain combination of movements that take priority - I have never dwelled on it enough to figure it out.
