John Deere 6320 tractor throws code 306057.31
Book says faulty transmission enable signal. Tractor will not move when put into gear, throws blue light flashing. Anyone know what the problem is. Bad sensor or what?
You got that right! I like the comfort and ease of operation but the electronics is a pain. Only problems I have had with this
tractor have been sensors etc. Stupid electronic fuel pump has gone out four times since I got the tractor in 2006. And this tractor
doesn't even have all the bells and whistles of the newer stuff.
This is really a shot over the bow but this post in the 1st link on another forum came up by web searching that code. In the instances talked about there it was a faulty transmission pressure sensor also another person had the same code in a 7000 series and he found a chaffed wire harness. The pressure sender he gave the number for RE217077 I want to say seems to have multiple applications on your tractor. You can check it out yourself on the JD online parts catalog in the second link. Beyond this you may be stuck calling out a JD dealer, unless you know of another independent shop that does this type of work.
AT Post with info
JD parts catalog
we got many tractors.h farmall to 8330 jd 4455 is great 4440,4250 cx 70 but newer seems sensers n other over priced little lectric gadgets stop newer machines
RE217077 3 tractor locations from parts catalog search on 6320 are shown below in photo.
